Easy way to convert 2012 VIs to 2011 VIs
Greetings NI community,
  Quick question - well hopefully quick - I have written VIs in 2012, but some collaborators I am working with ask me to send them in 2011. And I thought you could cut and paste, and sadly, I found out you can't do that! Smiley Very Happy
   Is there a way to "back-convert" 2012 VIs to 2011 VIs for those that haven't upgraded to 2012 yet?
  Thanks!
   TheLT
(2,583 Views)
Accepted by TheLT
menu...file...save for previous version
(2,581 Views)
In the File menu you have the Save for Previous version option is there through which you can save the vi's or project in an earlier version.(3 min delay 🙂 )
(2,579 Views)
Thanks to you both. I hooked you both up with kudos!
TheLT
(2,540 Views)
