07-13-2010
05:39 AM
- last edited on
09-24-2026
11:21 AM
by
Content Cleaner
Hi! I would like to create an Edge Strength Profile. I found a link::
http://digital.ni.com/public.nsf/allkb/34E524B23E9B88C28625711D000E2027
and tried to do the same... but the result is different in code and profile too. I could you help me to correct it?
I attached my solution:
07-13-2010 06:23 AM
I assume you would have seen this line in the knowledge base article
"Understand that the method above will create an edge strength profile that does not exactly match the edge strength profile found in Vision Assistant and VBAI.".
Can you post your orginal image?
07-13-2010 07:22 AM
Hi!
The Image from VBAI - Battery Inspection:
BTW, The Derivative function prameters in the site are not accepted by the function...
12-10-2010 05:50 PM
Any Suggestions?
01:20 AM
- last edited on
09-24-2026
11:21 AM
by
Content Cleaner
Here is NI solution!
I used this one!
12-13-2010 11:48 AM
Any solution including the filder width and steepness parameters (similar to Vision Assistant)?
