Edit Palette Set disabled?
recently lost my hard drive so just reinstalled LabVIEW 8.6.1f1 and 9.0f3
now (and this is in both 8.6 and 2009) when I right click the Function palette and Control palette open on the Express; for years I have been opening to Functions to Programming and Control to Modern. But I cannot change it - going to Advanced > Edit Palette Set opens the dialog, shows Current Palette Set is Local Host, but the 2 palette sets are un-editable and the View button is greyed out. is there some priveledge that I need to set? Seems I've done this before (way back when) what's changed?
thanx
lmd2
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(3,853 Views)
Accepted by lmd2
lmd2,
I think what you may be wanting to do you'll find by first pinning a palette
Then select view to either change the standard view or visible categories.
Hope this is what you were looking for.
James
LabVIEW 5.0 seems so long ago...
(3,836 Views)
okay
that is what I get for reading the help
DO NOT go to Advanced > Edit Palette Sets ...
just pin up a palette in the work environment -
yeah thanks, jrjones
I figured it was something simple
cell: 516.819.9711
(3,827 Views)
I can change the view of my functions palette but after I close the palette and then reopen it, it's reverts back the the Category (Standard) view.  When I was running LabView 8.6 I could change the view and it would stay to the view I had changed it to.  How do I save the palette view after I change it on LabView 2009?
Danny
(3,694 Views)
Go to Tools > Options... and select the Controls/Functions Palettes
Then, select the Format and Navigation Buttons you want from the drop down menus.
I like to set Format to Icons and Navigation Buttons to Icons Only.
Hope this helps,
James
(3,685 Views)
