Edit multicolumn listbox or table header while VI running
As this issue has been risen on LAVA, I checked and didn't find it reported yet.
The issue is when one wants to edit the multicolumn listbox' column or row headers while a VI is running.
By setting the Edit Position property to {-1,0}, it should be possible to edit the first column header. Instead, the {0,0} cell is selected. This behavior occurs also with row headers. The detailed help specifically says that -1 edits the headers and that it's a writable property settable while the VI is running.
The same error occurs with "Table". The only difference is that for tables, there is a "Editable headers" property that needs to be set to TRUE. If false, the edit position returns {-2,-2} as expected. However, when true, it returns {0,0} similarly to multicolumn listbox.
GCentral ChampionCLA
Message 1 of 11
(6,641 Views)
Hello normandinf,
Could you attach the VI here?
Which version of LabVIEW are you working with?
Andy Chang
Message 2 of 11
(6,604 Views)
This is LV 8.6
Message 3 of 11
(6,591 Views)
As a side note, I couldn't find the property to programmatically set the value of Table.Property.Editable headers. It is available through right-click on the control, but not found in property list. Perhaps I didn't dig enough?
Message 4 of 11
(6,590 Views)
Hello normandinf,
Thank you for the report, I've filed a corrective action request (CAR#178213) and our R&D group will be investigating this further.
Andy Chang
Message 5 of 11
(6,569 Views)
Is this ever going to be fixed in LabVIEW?
It still doesn't work properly in LV 2012....
Thijs
Message 6 of 11
(5,786 Views)
It doesn't seem to be fixed in LV14... Is there a workaround?
Cheers
Message 7 of 11
(5,490 Views)
Hello Jimmy,
Thank you for your post. This is a known issue in LabVIEW and currently there is no workaround. However, it has been documented and submitted to the LabVIEW Development Team!
Have a nice day,
Message 8 of 11
(5,467 Views)
Oh my gosh!
"Known issue" for over SIX years and still not fixed??? What other non-essential "feature" is R&D busy with?...
Message 9 of 11
(5,235 Views)
Is there some platform we can use to vote for CAR priorities?
Message 10 of 11
(5,219 Views)
