fpga
I am trying to run an example program to test my motors that are connected to my cRIO. I complied my FPGA target and the compilation was successful. I then ran my real-time program 4 times and everything worked fine. Then suddenly my real-time program won't run anymore saying "operation cannot be completed because one of the scanned I/O buses is not in the required I/O mode".
Any help or advice?
(3,145 Views)
Hi EricInstrument…,
In most cases, deploying updated settings automatically triggers the NI Scan Engine to switch from Active mode to Configuration mode. However, in some cases you may get the following deployment error: "The operation cannot be completed because one of the scanned I/O buses is not in the required I/O mode." This error usually occurs when you update only the NI Scan Engine Scan Period using the Scan Engine Page of the Properties dialog box. To try and fix this issue I recommend following this Knowledge Base article:
http://digital.ni.com/public.nsf/allkb/E547F5A8D1404B3F8625768700834C88
regards,
(3,106 Views)
