how do I use the instrument IO assistant block to analyze and compare my experimental voltage values with that of my calculated voltage values?
How do I use the instrument IO assistant block to analyze and compare my experimental voltage values with that of my calculated voltage values?
(3,015 Views)
You can't. I would never use the assistant but if you insist, use it to return your measurements and regular LabVIEW functions for the analysis and comparisons.
(3,008 Views)
You can only use Instrument IO Assistant to acquire data, for analyze and compare you can use any of the VI shown in the following link
http://www.ni.com/tutorial/9319/en/
JBarrman
Applications Engineering
www.ni.com/support
(2,967 Views)
