Edit rownames in multicolumn listbox at runtime using keyboard
Message 11 of 23
(2,440 Views)
Here you need to follow some order
Get the cell position from Point to row column and then provide thsi cell position to MCL Property node as Active cell the use another property node to get active cell position
Maintain the same execution flow you will get the active cell position
Message 12 of 23
(2,438 Views)
Find the attached image for your Reference
Message 13 of 23
(2,433 Views)
Ah fine.
Still the indicator is not in the right position:snip.png
Message 14 of 23
(2,428 Views)
you want to place the numeric indicator in the MCL in the specific cell which you click right?
long before the expereinced the same and it worked for me.
Even you can use visible peoperty to make the numeric indicator only visible after clicking the cell
Message 15 of 23
(2,424 Views)
Have you  tried my snip? I can't get it working
Message 16 of 23
(2,417 Views)
Attach  VI...
Message 17 of 23
(2,414 Views)
After setting the position of the Numeric control, try to use the property "Key focus" of numeric control. So that when user types in the keyboard, it will update the value of Numeric control.
Then try to set the value of the particular cell in list box, using "Numeric ctrl" Value change event case.
Message 18 of 23
(2,407 Views)
Your Control hides behind your MCL, so select the Numeric control and use brint to front (ctrl+Shift+K)
Message 19 of 23
(2,392 Views)
Thank you for your advices 🙂
Nearly there now. Only the position of the numeric is not perfect.
Message 20 of 23
(2,385 Views)
