Editing a subVI's input lines
I'm working with a piece of code created by the (unfortunately recently inactive) author of this example. In short, the code feeds a square wave to user-selected lines on a NI-DAQ. I'm trying to make adjustments to the array below, such that each of the cells/elements includes a control/menu for an offset. As is, the user can only specify frequency and duty cycle, but for my application, I want to be able to include an offset to the square wave. image.png
I can go into the array for this and customize it so that there's a third field in each cell titled 'offset,' but the problem is that the "Generate PWM" vi doesn't update to have an input channel for the new entry field I created. I'm not sure how to edit "Generate PWM" such that it will take another input line. (image illustrating this below)
image.pngAbove is "Generate PWM.vi" -- I've made an adjustment already: I added in that double/control (offset) to as the function generator has an input line for offset already. I don't know what parts of the VI determine the inputs it will take when used as a subVI in the larger "Cont Gen Dig.." VI I've attached.
Any help or insight is greatly appreciated
(3,127 Views)
Accepted by topic author vomojo
(3,100 Views)
Thanks, that solved the problem! Now the subvi accepts the info in the phase field.
(3,045 Views)
