06-09-2017 10:35 AM
Hello.
Can any one help me understand how to acquire data simultaneously from two analogue channels in synchronization?
I want to acquire two different waveforms using two different analogue channels such that the channels are reading the waveforms simultaneously such that the acquired waveforms are synced together.
Solved! Go to Solution.
06-09-2017
11:55 AM
- last edited on
06-18-2025
05:47 PM
by
Content Cleaner
You can install it right from VIPM too.
06-09-2017 12:03 PM
will it work with myRIO?
06-09-2017 12:12 PM - edited 06-09-2017 12:12 PM
I'm not familiar with myRIO, but it's pretty easy to set up and try for yourself. I'm using it on a cRIO right now.
06-09-2017 08:25 PM
If you are on the FPGA, just expand the I/O node and all of the inputs read from that node will be synchronized.
