Problems calling dll or loading .net assembly - microchip MCP2210 with labview 2016 x64
Hi everyone,
I am using MCP2210(USB to SPI bridge) but now i have a problem with labview2016 x64.
i 've already add labview.exe.conf file as http://digital.ni.com/public.nsf/allkb/32B0BA28A72AA87D8625782600737DE9?OpenDocument
but now  i can't load old vi using lv2016 x64 and i don't want to reinstall older version.
and i also can not import some of the functions using the dll import wizard.
the dlls is attached.
thank you for your help.
(3,648 Views)
I had no trouble with either the 32 or 64 bit dll inports.
A small subset of functions couldn't be imported due to a missing "windows.h" include file - are those the functions you mean? If so, you'll probably need to download the windows SDK. A quick Google search should get you to the right place - a starting links might alternatively be:
Using the Windows Headers
Windows SDK for Windows 7 and .NET Framework 4
You don't specify your Windows version, but I guess you can find the appropriate download from those links.
GCentral
(3,619 Views)
thank you very much for that.
i tried download windows sdk but still can't get all of them working.
plz check the error attached
thanks.
(3,607 Views)
