Editting the scale on a gauge
I'm using a gauge as an indicator for wind direction and another for speed. The speed gauge looks like this.I have rotated the scale so that the "0" and the "50" overlap. I want the "0" to be displayed, not the "50"I've tried editting the text labels with no luck. Any ideas. Thanks in advance for the help.
(3,754 Views)
I am not sure is that the right way, but attached is what you asked.  In edit mode, i pasted "0" with white background over "50" and move "0" to the front.  I also have to move the needle to the front, so that it will look correct.
Kudos and Accepted as Solution are welcome!
(3,703 Views)
I ended up just changing the scale>style to show just the tick marks and added my own numbers. Thanks for the help.
ssmith
(3,672 Views)
a very good document with several examples can be found here
(3,669 Views)
Thanks you for this info.
ssmith
(3,664 Views)
shhhh, the secret word of the day is "text labels for scale markers"....gauge_FP.png
(3,655 Views)
That was a great tip, apok.
(3,632 Views)
