Efficient way to generate a string of fixed length
What is the most efficient way to generate a string of a pre-set length using padding with white spaces when necessary?
For example, I have first string = "short string" (12 characters including a space) and I want to convert it into second string "short string    ", 16 characters long, white space (or any other character) padded. I would like to have a pre-set length of the second string regardless of the length of the first string. Can I do that efficiently, without loops?..
Message 1 of 9
(12,083 Views)
Accepted by topic author MichaelSolo
1. Initialize Array to create an array of U8 based on whatever length you want.  A space would be 32, or 0x20.
2. Byte Array To String (which is basically a no-op)
3. Replace String Subset to replace the first X elements of your new string with the old string, where X is the length of the old string.
Message 2 of 9
(12,077 Views)
Thank you!
Message 3 of 9
(12,071 Views)
Yes. Use Initialize Array, with the element set to a U8 containing the ASCII code of the space character and length set to the desired string length. Convert your initial string to an array of U8 using String to Byte Array. Use Replace Array Subset to put that into the pre-allocated array of spaces, then convert back to a string using Byte Array to String. Conversions between strings and byte arrays are basically free operations (a string is an array of bytes) so this is efficient despite the conversions.
There are other similar approaches, for example you could subtract the existing string length from the desired string length, allocate an array of that number of spaces, convert to a string, and concatenate the spaces onto the end of the existing string.
EDIT: Looks like I was just a bit too slow to respond, and crossrulz beat me to it with a similar idea.
Message 4 of 9
(12,070 Views)
Format Into String is a handy tool for string manipulation.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 5 of 9
(12,054 Views)
This is the best!!
Message 6 of 9
(12,051 Views)
This is the simplest possible way, no doubts!
However, the output string cannot be longer than 4096 characters. The array-based method above though not as elegant, does not have this limitation.
Message 7 of 9
(12,028 Views)
Interesting. It seems to be a hard limit and there's no mention of it in the help file.
I was not aware of this so thanks for the information!
steve
Message 8 of 9
(11,958 Views)
Thanks was exactly what I was looking for.
Message 9 of 9
(11,196 Views)
