Efficient way to move graph value from SubVi to main vi ?
I would like to seek your opinion on the most efficient way to move mixed graph data ( value and if possible together with all the other associated properties ( plot name, Yscale.namelbltext etc) from the SubVi to the main vi. Currently I am using a good number of property nodes in the SubVi ( Necessary because I need to customize certain things such as plot area height dynamically) with refnum controls to transfer the graph data and the associated properties from the SubVi to the main Vi, but I would like to know if there is a more efficient way to do this.
[BADGE NAME]
Message 1 of 15
(4,341 Views)
Use a queue.  Enqueue the data in the subVI.  Have the main VI dequeue it in a loop and write the values to the graph's terminal.
Message 2 of 15
(4,333 Views)
Sounds very interesting. At your convenience kindly include a litttle vi to illustrate the process of enqueue and dequeuing. I am still learning a lot of things.
[BADGE NAME]
Message 3 of 15
(4,322 Views)
Also, would the associated properties also be transferred along, or just the values?
[BADGE NAME]
Message 4 of 15
(4,319 Views)
In a queue generally you can transfer anything you want but the point is whether you really need to do it. Why are you setting all the properties in a sub vi? Are you going to display the sub vi front panel to the user? In that case why would you want to transfer everything to main vi and also how is your main vi and sub vi related? If possible attach the main and the sub vi for getting into a proper solution.
Message 5 of 15
(4,314 Views)
Search the forums for producer/consumer.  Also the example finder in LabVIEW and the New... file menu has a producer/consumer template.
The queue sends along values.  You asked for an "efficient way to send values" and you said you were doing the manipulation of control properties in teh subVI.  You can send along combinations of data in whatever format you want.  You can define a cluster that can be any combination of datatypes you want.  A very flexible cluster is one that contains a cluster of an enum so you can send a "command" and a variant which can package any different type of data.  On the receiving end, you read the enum out of the cluster and decide what to do.  You can then convert the variant back to a specific datatype.
Message 6 of 15
(4,310 Views)
For an example, take a look at the Producer/Consumer architecture.
Only the values would be transfered between the VIs.
GCentral
Message 7 of 15
(4,307 Views)
Thanks "worthy Knights" :). I will take a look at the producer/consumer example
[BADGE NAME]
Message 8 of 15
(4,305 Views)
One quick question that comes up just taking a glance at producer/consumer vi is: what happens if my SubVi is not in a Loop? Actually I have the subvis placed inside case structures in the main vi loop
[BADGE NAME]
Message 9 of 15
(4,297 Views)
Attached vi shows what I am thinking of doing. Becasuse i can not have both vis side by side i am thinking i should place the "queue out" on a connector pane out of the subvi which will then feed into the "queue in" on the main vi. What I dont know is whether this is as good as placing the 2D array directly into a connector node which i guess  impacts negatively on memory and performance?
[BADGE NAME]
Message 10 of 15
(4,290 Views)
