Elapse timer
I am doing this motion sensor project. i have gotten it to work like when it senses a motion it will light up the boolean led. so now i am suppose to add a some sort of timer which some has recommended me elapsed time, i tried figuring out but i dont know how to wire it to my program. My task is to set a timer, so that when 10 mins has passed and no motion is detected it will trigger a logic 1 ( Digital Input ) to another program. But right now im focusing on this program as i need to integrate both. So how do i wire it to make it like how i had described. And lastly i need a reset button so that after it input a logic 1 ( which will trigger a alarm - another program ) it can be reset and countdown 10 mins again. Thankyou
(5,100 Views)
Hi bobfun,
you already asked this in a different thread.
Instead of creating double posts you should keep related things in ONE thread. This will help to bundle information in one place!
As said before: use the ElpasedTime expressVI. Wire your "no motion" condition to the expressVI and you will get your signal, when the time has elapsed…
(5,075 Views)
Hi GerdW,
Im so sorry as it was my friend who posted it for me the prevous time. So where do i wire it to? do u have a pic so i can better understand what you meant? and what about the reset button? im so confused as i have not learn this before. thank you very much!
best regards,
bobfun
(5,057 Views)
HI GerdW,
Sorry to bother you again, but how do i set the time? i have to wire the Elapse time or the Presents or Time has Elapse? I dont really get all of this as i have not learn LabVIEW before. Mind if u could explain to me? Thank you very much.
(4,981 Views)
Accepted by bobfun
First, you should continue in your original thread.
Next, take the LabVIEW tutorials.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Then, read the help file for the Elapsed Time function.
Finally, set up a simple VI where you can experiment with how that function works.
(4,974 Views)
Thank you very much for ur help! have a nice day!
best regards,
bobfun
(4,954 Views)
