Email
Hiii
I am using Labview7.0. I want to send excel file through SMTP Email Send File.vi.
Using SMTP Email Send File.vi I am successfully able to send .txt file but I am getting problem in Excel file only.
Pl give me solution for How to send Excel file through SMTP Email Send File.vi?
vijtin
(4,406 Views)
Accepted by vijtin
Hi vijtin,
try to change the boolean input to true (if you didn't do it), because an excel file is binary.
Mike
(4,389 Views)
Hii Mike
Thanx for giving right solution. By making boolean input to True i am now able to send & open excel file properly as i wanted.
I have another problem facing in Labview7.0 in DSC.
While doing Launch Engine (By clicking Tools->DSC Module->Launch Engine...) my communication gets starts but labview gets hang & i am getting error screen which i am sending you in attachment. After this error i am not able to do any function & finally i have to close application through TASK MANAGER....(ctrl+alt+del).
Plz give me solution.......
vijtin
(4,367 Views)
Hi vijtin,
i'm not very familiar with DSC. You should start a new thread for this topic to get more responses.
Mike
(4,360 Views)
Have you tried to create a new .scf file with the Configure Tags option. Can you open the exsiting .scf file with the Configure tags option??
(4,355 Views)
Instead of embedding a huge bitmap image inside a zip file, that doesn't seem to have compressed the file size just enough to make it still a large zip file, next time just post the picture as either a .jpeg or a .png.
(4,352 Views)
