Embed VLC into WebVI (NXG)
I tried to embed a video-stream into my WebVI by inserting following into HTML Source: https://webcast.xxxx.com/xxxx/streamname/playlist.m3u8 (sensored for privacy), but it doesn't seem to work with .m3u8. Previously I managed to embed a .cgi-file. Does anyone have experience with embedding .m3u8?
BR
(2,377 Views)
Accepted by RoboNuC4
Hi RoboNuC4,
I was able to use the video.js library in order to embed a m3u8 stream into a WebVI. The WebVI can be seen on GitHub and is playing the University of Texas Falcon Cam.
One thing to keep in mind is that m3u8 is a very flexible format so it's possible the video.js library may not support your specific video. You can see the video.js troubleshooting page discussing their supported formats.
Attached is an example project using the video.js library to play the falcon cam m3u8 stream on a WebVI.
Milan
(2,331 Views)
Hi Milan!
This worked great, thank you so much! 🙂 Now I just need a way to implement this into my code 😄
(2,302 Views)
(2,296 Views)
