Empty Numerical Constant?
This is more of an asthetic thing than anything else, but I am looking for a numerical analog to the 'empty string constant'.
I am going to save this data to a file with the 'write to spreadsheet.vi', the array of strings on top will be saved first as a header for the data that is in the lower array.  I would like to separate the peaks and valleys with an empty column, and would rather not just have a giant column of zeros.
(5,464 Views)
Accepted by topic author LarsUlrich
There is no such thing as an empty numeric. I would suggest you simply convert everything to strings.
(5,461 Views)
Yeah that's what I was thinking I'd have to do.  Thanks for the advice!
(5,454 Views)
Hi Lars,
how do you input an "empty number" into your calculator resting on your desk or drawer? 😄
I really look forward for a concept of math involving "empty numbers"…
(5,436 Views)
If dealing with floating points, an "NaN" might help....
Norbert
Norbert
Expert: Geometry
(5,420 Views)
