Enable Calendar function using Active X
Hi all,
Does anybody can help me how to enable Active X function Calendar.
Please refer attachment.
(3,484 Views)
(3,482 Views)
Hi, I just follow the step by step procedure but I can't see the objects select "Calendar Control 8.0"
Is my PC need any setting or installation?
(3,442 Views)
That control usually comes with MS Office. It's called mscal.ocx. If you do not have this file on your system (do a search), you can get it here.
(3,427 Views)
