Enable to have the Write File to Citadel Example working
Can any other example write to the database successfully?
Message 11 of 14
(823 Views)
Well, I can log data in citadel using the usual tag engine and the log data and events. At the moment, it is the only way I can use to store data in citadel.
But this is defferent from the import process I whish to use.
Message 12 of 14
(823 Views)
Hi Dr. Tag,
I went through all my problems, and have the import process working fine. At last.
Thanks a lot for your valuable help.
Hélène.
Message 13 of 14
(823 Views)
Your story is exactly the same as mine. I've tryed to run the same example using Labview 7.0 and it behaves as you reported with your previous version of LabView. Could you tell me what is the trick to solve the problem?
Jose Javier
Message 14 of 14
(823 Views)
