I have solved the problem that ring of strings typedef are not updated after a long time of searching by adding EnableStrictTypedefConstantConfiguration=True in labview.ini
the problem is after starting labview again this option even that is already in labview.ini, Act as strict typedef constant is not showing anymore when i right click on the string ring!
can someone please help me.
