EnableStrictTypedefConstantConfiguration ist not showen anymore
Hello, I have solved the problem that ring of strings typedef are not updated after a long time of searching by adding EnableStrictTypedefConstantConfiguration=True in labview.ini the problem is after starting labview again this option even that is already in labview.ini, Act as strict typedef constant is not showing anymore when i right click on the string ring! can someone please help me.
(922 Views)
Hello, I have solved the issue, i had to make the typedef as strict in the frontpanel. Thanks anyway.
(916 Views)
