Enabled from boolean.vi for GUIs
Hi George, all,
George Gatling wrote (in part):
>The latency between pressing the sweep button and seeing data
>on the screen is here to stay. What techniques do you expert
>GUIers use to discourage repeat clicks on the sweep button?
>I have had my own ideas such as disable and greying the button...
>using a modal "Please Wait" dialog... I am curious what would
>be considered an elegant or at least widely accepted way
>to handle this sort of delay. ... the delay is 1-2 sec -5 min
I don't know that there is a "standard" way, a lot depends on personal and
corporate style, but I find a combination of disabled & grey with some type
of movement to indicate that a process is on going gives the operator
assurance that the application isn'
t hung while preventing them from
pressing that button (or twiddling that control) again.
For motion I often borrow the spin indicator off the Library Manager under
the LabVIEW tools menu. If you open the Librarian, then hit ctrl-. (Windoze,
YMMV) the VI aborts and you can pillage the parts village at will. If you
click-drag the area between the two upper menus you will get an outline of
an ?mpty" box, which is a picture ring. Double click on that and you'll see
the code segmant that runs the ring. Its in a while loop in the bottom
section of the diagram.
As for Enabled/Disabled-Grey, I got tired of the real-estate taken up by
handling this so I coded up a simple small-icon VI to switch between Enabled
and Disabled-Grey by a boolean input (does anyone use the Disabled without
the grey a large percentage of the time?, just curious). I've attached that
here, for posterity.
Mike Ashe
[Attachment Enabled from boolean.vi, see below]
(2,660 Views)
you wrote:
[...](does anyone use the Disabled without the grey a large percentage of the time?, just curious).
I seldom use disable without the grey on controls. I use it mainly on numeric/string indicators to prevent to user to select the data. It is confusing when one can select(hilight) the string and there is nothing else to do with it (except Copy Ctrl-C).
LabVIEW, C'est LabVIEW
(2,660 Views)
