constants
I have a device connected GPIB as part of a sequence i need to increment the power supply in 6 pre-defined steps what is the easiest way to code arrays??
(2,562 Views)
Easy. On the array palette, is the array constant. Drop that onto the diagram and then drag a numeric or string constant into the array. Those constants can be found on the Numeric and String palettes.
(2,562 Views)
