Enabling or disadbling multiple pages on a tab control programmatically
I am trying to create and HMI using the tab control. the first page is the login screen which only moves to page 2 when the write password has been entered.
I want to disable and grey out the other tabs until the right password has been entered. when the correct password has been entered, I want to enable and make visible all the tabs.
Currently, i can only do this for one tab in both scenarios. I tried using index array but I cannot connect to the property node as it says the source is an array and the destination is a reference.
Please any suggestions?
Thank you.
(25,261 Views)
Accepted by AIG7
(25,228 Views)
@hama-mmc
Many thanks for the support. tis working the way i want it to.
Appreciate
(25,215 Views)
