Enqueue and dequeue cluster then save to TDMS file (or other file?) in producer-consumer
Hi all,
I have a producer that is reading from an accelerometer using DAQmx Read
I want to send the waveform data from this (2 channels of data, X axis and Y), as well as the current time (using the 'Get Date/ Time in seconds' VI, i.e. a timestamp), the loop iteration count (32 bit integer), and a reading from a clock I made on the front panel (output is a 1D array of doubles) - for each loop to a consumer, that saves it in TDMS (or other) format.
I am having some weird issues. I can't seem to set up the cluster constant right. I put in 2 waveforms, a timestamp, an integer and a double but I get an error saying I am trying to put a 'cluster with a waveform and a waveform double' a cluster with '2 measurements, and a waveform of doubles'. I noticed that when I go to dequeue the cluster where I put in two waveforms, it is showing 2 'measurements'... so its changing the data type in the queue.
I thought maybe you cant send a whole waveform into a queue, so tried breaking it down into its dt, Y and t0 (and changing the cluster constant to allow this) - but then it said I was trying to connect 7 items to 9 - which I wasn't. So I know I am missing something, but I can't quite see what...
Also, will a cluster just save into a TDMS file? or do I have to flatten it/ write it to a string or something (things I read online but not sure apply). I would like to have each input in a different column (waveform1, waveform2, time etc...) and then each sample/ iteration in a different row in my saved file...
Any help would be amazing... I have added some pictures - the first is the original, the second has some broken stuff in it I tried (mostly disconnected, but to show my *working*)
Thank you!!
(3,375 Views)
Make a type-def of your cluster and use it to both create the queue and at the point where you enqueue.  Then you will not have these mismatch problems.
(3,368 Views)
Accepted by hdempseyjones
HI hdempseyjones,
You have to initialize your queque with this.
I have also attached the update vi. Give kudos if you like it.
CLD Using LabVIEW since 2013
(3,340 Views)
Thank you! I really need to learn more about type defs
(3,324 Views)
Ahh, I see! So the cluster I was initialising contained two 'measurements' with waveforms inside, which you now replaced for just waveform elements. This seems to work nicely! Thank you
I was just wondering, regarding the second part of my question - how to save the output of this cluster to a file. I am not sure the best way to do this. In my ideal scenario I would have each element of the cluster in its own column of a TDMS file (with one row per loop iteration). At the moment I have just unbundled everything, formatted it all into a string together and saved that string (one row per loop iteration). Is there a better way to do this, ideally so I can get one cluster element per column)?? [first image]
In a related question, I am saving two arrays into a TDMS file with single values (doubles) [second image]. The way I am doing it seems to work fine but I think there is also probably a nicer cleaner way (also maybe where I could label the values?)
Thank you all!
(3,315 Views)
