11-30-2009 10:47 AM
From the other threads here and here, i got excellent support from David and Thomas. Thanks all. ![]()
The envelope of the signal coming out as per David's example is in form of XY Graph. But as per Thomas' example, i need waveform graph in this format so that i can find out some of the rising and falling edge values in the waveform. So kindly suggest me how to handle this conversion. Thanks.
Mathan
Solved! Go to Solution.
11-30-2009 01:09 PM
11-30-2009 01:14 PM
11-30-2009 01:41 PM
11-30-2009 06:14 PM
Dear aeastet,
All i can say is simply superb and very perfect.... Thanks very much.... ![]()
12-01-2009 07:39 AM
12-07-2009 07:42 AM - edited 12-07-2009 07:44 AM
Dear aeastet,
Thanks a lot for all your help. I do need some more favor.
I now replaced all the previous drivers for my Tektronix oscilloscope with the newer ones and now instead of amplitude versus number of samples, the output from the oscilloscope graph will be amplitude versus time (directly). In this case, what i need to give to the for loop input (you gave 30 in the previous case). David in the other thread mentioned it was the number of Zero crossings in the waveform(Hope he will watch this thread also and will do some favor for me). I didn't understand that term. Kindly can you explain me the working principle of the program. Thanks a lot again for all your inputs.
[Edit: I unmarked it from solution, since i assume that a solved thread will only get less inputs. I will mark it as solve again when i get my problem solved. Thanks]
Mathan
12-07-2009 07:48 AM
12-07-2009 08:27 AM
12-07-2009 08:29 AM
