Erro open agilent 34970a
Hello, I'm very new on Labview, I'm using an agilent 34970A. (I'm french, sorry for my english).
I've made a small program with agilent drivers to get temperatures and it does work.
I would like now measure a voltage. I can read it directly on the front panel of the agilent, BUT when i try to read it with the labview programm with the function monitor, the front panel indicate that the channel is open, which is not because I could read it one minute before with the front panel.
I don't understand the problem because my program is very simple and excutable, there is no communication trouble between the computer and the agilent, so i'm really asking with does the agilent indicate that the channel is open ?...
I'm sorry for bad explications, I hope your understand my trouble, I've give you some picture to illustrate my purposes.
Thanks a lot  in advance
(2,674 Views)
(2,663 Views)
