Error 0xBFF6001F - Cannot detect recognizable video source
I'm using a NI PCI-1433 card with a Sentech camera.
When I try to get a snap from the camera in MAX, I've the following error : 0xBFF6001F - Cannot detect recognizable video source.
I use the icd file given by the camera constructor (Alliance Vision) for the camera parameters.
I have Labview 2012 SP1 and MAX 5.4.0.
Has someone any idea ?
Maugan.
(2,931 Views)
Can MAX "see" the camera?  If you open MAX and have it "detect" stuff, does your camera show up?  If so, I'd expect MAX to be able to open it.  If not, then you have a problem!  Does MAX see the NI PCI-1433 card?  [I've not used cameras connected to cards like this -- my experience has been with USB or Ethernet cameras.]
BS
(2,906 Views)
Hi Maugan,
Did you already look at this KB?
Best regards.
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(2,889 Views)
