Error 0xFFFEFA46 when deploying Web Services to CRIO RT Target
LabVIEW 2023 Q3 64 bit. CRIO-9032 RT Target. RT-VI is running. Web services work on debug server. But deploying them to to application web server (by right click in the project on the web services) gives this error:
Error LabVIEW: (Hex 0xFFFEFA46) LabVIEW Web Services: Call to create a reference to the LabVIEW application failed.
How can I deploy the web services?
(1,901 Views)
Hello JR
do you have any news to this issue?
(1,723 Views)
Same issue, any news?
(1,442 Views)
Accepted by clicks
update: the problem was solved as follows:
downloaded the RT System Image 2024 and did a new format/update on the cRIO
(1,162 Views)
