Error 1 reported wth Application builder using Labview 2013
I am using Labview 2013.
Unfortunately I cannot post my code online.
I am getting Error 1:
Error 1 occurred
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be Controller-In-Charge.
On debugging of the error, I figured out this is Labview Error and not NI-488 error.
The SubVI that gives an error, can be converted into executable by itself no problem.
I see the error only when I try to include the subVI into the Main VI and try to create executable for the main VI
The subVI that gives the error, it has 3D plot polymorphic VI. I went on deleting all the code into the subVI to see which code gives me error, it turns out if I have the 3D plot code into the subVI it gives an error, if not there is no error.
Any help on this would be appreciated.
One of the SubVIs I use
(3,004 Views)
Hi gyg
What I can found about Error 1 happening when you are building a project and have helped a lot of people is described in this link
http://forums.ni.com/t5/LabVIEW/Build-application-still-fails-with-error-1-in-LV12/td-p/2279948/high...
Try some of the recommendations people said there and keep us in touch
(2,939 Views)
