Is there a performance loss or gain when enabling 'make available through property nodes' in class accessor?
QFang
Active Participant
As the topic states, I'm pondering if there is a performance hit (or gain?) by making class accessor available through property node?
Specifically, I wonder if the 'class accessor property node' is somehow different than 'normal' property nodes, which I tend to avoid as best I can due to how they often involve the GUI thread and are often detrimental to performance.
And since the follow up question to any answer would be to ask if including error handling terminals changes the answer?
-People who write LVOOP on a semi-regular basis or more, is there a concensus on when/if you use the property node option?  Is it preferred as a default almost? Is it affected by whether the accessor is dynamic or static?
Thanks!
QFang
QFang
CLD LabVIEW 7.1 to 2016
3 REPLIES 3
mikeporter
Proven Zealot
Re: Is there a performance loss or gain when enabling 'make available through property nodes' in class accessor?
This is a far from technical answer but I don't use the property node option because it's a separate option that you have to remember to click, and property nodes take up way to much space on a block diagram.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
tst
Knight of NI Knight of NI
Knight of NI
As far as I know, there is no difference between a subVI call and a property call and they should behave identically behind the scenes. There shouldn't be a forced call in the UI thread, because these don't deal with UI elements. It's simply a different syntax, so it should be the same for DD. I have seen some complaints about performance issues and/or bugs in earlier versions, but I don't remember if there was anything concrete. You can search on LAVA.
Likewise, I don't think the error I/O itself causes delays, but both the serialization of the calls and having case structures acting on those errors can. AQ had some posts on that and he dislikes both. Personally, I tend to like the readability, particularly for serialized calls. Note that some people don't like accessors (at least public ones) as a concept, suggesting that having writers for individual fields leads to all kinds of troubles, and that it's generally better to have specific functions with the relevant inputs.
___________________
Try to take over the world!
QFang
Active Participant
Thanks for your input guys!  I appreciate it!
QFang
