Error 10 occurred at AB_Build.lvclass:Preview_Build.vi
Hi All,
I had a completely working LV project in LV2009. We upgraded to LV2011 and now when I build this project, I get the following error.
Error 10 occurred at AB_Build.lvclass:Preview_Build.vi -> AB_Application.lvclass:Preview_Build.vi -> AB_EXE.lvclass:Preview_Build.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Duplicate path.
NI-488: Asynchronous I/O operation in progress.
Also, the stand alone executable created earlier doesnot work on one of my work stations and keeps giving me errors that it is missing Report Generation vis like the ones under .../vi.lib/Utility/NIreport.llb. The work station does not have LV installation but works out of a Run-time engine alone.
Your help is much appreciated
PKI
(2,842 Views)
Hello PKI,
Maybe this (http://digital.ni.com/public.nsf/allkb/AF12BB5FAC27FE2186256F9400619C84) can solve your issue?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,840 Views)
