Opening a data storage file after the Labview code ends storing the data
Hi to all,
In my code, I am storing the data related to the status and quality of the devices like pressure and temperature in TDMS file. I just wanted to know if there is a possibility for the user to view this data in MS Excel automatically when the program stops. Of course this can be done manually by going to the folder which stores the tdms file. But i just had this idea. If it is possible then can you please give me some ideas as to how to make it. I don't want to use a TDMS viewer. I hope my prblm is clear. If not please let me know.
Thanks a lot for viewing this post.
KEMLab.
(2,672 Views)
KEMlab,
You could use this add-on for excel and activeX to do this.
(2,649 Views)
Thanks a lot. Will give it a try.
(2,642 Views)
