Help getting started: externally triggering a 7841R FPGA
  I'm a relatively inexperienced LabVIEW user with no experience with FPGAs.  I'm looking to produce a simple FPGA VI as a first use of our 7841R.  We synchronize multiple devices with a pulse generator and would also like to use the pulse generator to trigger our 7841R.  I haven't been able to find a simple example of how to do this*.  Here's what I think I've figured out so far:
(1) create a while loop
(2) add an FPGA I/O node for one of the digital input nodes (say, DI0) (or maybe this should be an I/O method?)
(3) ...this is where it gets hazy....presumably the I/O node produces some output that I can then use to trigger an event
(4) once triggered, change the voltage level on one of the analog output nodes
Any help would be appreciated -- especially pointing me toward relevant tutorials or examples.
Thanks!
Cheers,
tom
* I did work through a tutorial that has the FPGA output a sine wave and that worked great....but I've been stumped after a few hours of searching about to figure out the triggering.
(3,396 Views)
Accepted by topic author Mawx
Hello Tom,
Here's a first tutorial you can go through:
http://zone.ni.com/devzone/cda/tut/p/id/3261
This tutorial does it the other way around (triggering something by an analog edge):
https://www.ni.com/en/support/documentation/supplemental/21/designing-custom-triggering-applications...
This one is the most handy one according to me (also about custom analog triggering):
http://zone.ni.com/devzone/cda/tut/p/id/6359
It shows how you can trigger a digital output based on analog input value.
In your case you'll just have to do it the other way around:
Read in a digital value and then based on that write something to an analog output.
If these tutorials don't help you along enough, then don't hesitate to give us a sign.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,393 Views)
Thanks for the help, Thierry!  I've got some external triggering working already :).
(3,380 Views)
Great to hear that!
If any questions/issues pop up, then don't hesitate to let us know.
Kind Regards,
(3,366 Views)
