disable array indicator but enable scroll bar ?
Dear All,
is there a way to disable an array without disabling the ability to scroll down with the mouse (scroll bar is also disabled if you choose disable in properties). The array indicator is clickable althoug not writable but causes confusion for the user...as if you can write something.
thank you .
Message 1 of 9
(4,688 Views)
Disable just the array.element control and not the actual array.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 9
(4,678 Views)
how ?
Message 3 of 9
(4,672 Views)
Hi mbhatti2000,
- Could you put up a small example of what you mean?
If you just want to disable the array indicator and gray it out, then you can use the property shown below.
Peter D
Message 4 of 9
(4,669 Views)
See very crude example
Paul Falkenstein
Message 5 of 9
(4,667 Views)
sorry here is the attachment
Paul Falkenstein
Message 6 of 9
(4,666 Views)
In pete's example, rught clich on property node and select link to, then navigate to pane->array->numeric.  This is now a property of the lement contained in the array.
Paul Falkenstein
Message 7 of 9
(4,660 Views)
You can also simply right-click on the array element, choose Properties then select Disabled from the Enable State menu.
Message 8 of 9
(4,653 Views)
Good point, Darin - I was stuck in 'programmatically mode' Smiley Very Happy
Peter D
Message 9 of 9
(4,642 Views)
