Error 1003 occurred, "the VI is not executable"
Hello together,
I have following problem:
I can't  create a application of the VI "Excel open.vi" (see attachment, "Neuer Ordner.zip"). The error, see *.jpg -attachment, appears.
I work with LV7.0.
Is anybody there, who can solve this problem.
Thank you and best regards
zäpfle
(4,061 Views)
Read the help documentation for the toolkit, there are additional steps to perform when building an executable with dependencies from the Report Generation Toolkit:
http://www.ni.com/pdf/manuals/323805a.pdf
Keep in mind, these steps are different depending on the version of the toolkit as later versions no longer use LLBs.
-Bob
(4,041 Views)
Hello Bob,
thanks for your quick answer.
Unfortunately I couldn't found the "_Excel Dynamic VIs.vi".
Is that right, that I have to purchase and install the Report Generation Toolkit? Or is it possible the "_Excel Dynamic VIs.vi" get for free?
I use LV 7.0 Full Development.
zäpfle
(4,022 Views)
I will say you will need the tool kit
(4,014 Views)
This is really Pity, because the price of the toolkit is about 500 euros.
Well I have to program it, without the "_Excel Dynamic VIs".
I hope I get it.
Best regards
zäpfle
(4,010 Views)
Zapfle,
 There is a repository of code that interacts with excel located at
http://forums.ni.com/ni/board/message?board.id=BreakPoint&thread.id=2391
Please do not post questions on that board. You could also consider creating .csv files that can be opened in Excel.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,988 Views)
