How to programatically find the path to the project file
I'm trying to find a way to get the path to the project file in the development environment.
I have attached a small project in LV 8.5.1 with a project file, a library file and the VI. I can get the path to the library file but not to the project. This path is always <Not a Path>.
I know the problem exists in LV 8.6.1f1 but I didn't made a test in LV 2009.
I'm aware that in real world there could be more nested levels of  library files but that doesn't matter when this simple example doesn't work.
If this is related to the problem I first created the library using File >> New... and later I created the project and added the library.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,916 Views)
The forgotten project. It seem I'm getting old and forgetable.
Waldemar
(3,910 Views)
Accepted by topic author waldemar.hersacher
Hi Waldemar,
here comes a small piece of code and a related link.
http://forums.ni.com/ni/board/message?board.id=170&message.id=220269&requireLogin=False
Hope this helps.
With best regards
Ralf N.
Applications Engineering
NI Germany
PS: Don't forget the Kudos. :o)))))
(3,880 Views)
Hi Ralf,
I thought, that LV maintiains something like <project>:<library>:<VI>. I can see  <library>:<VI> in the titlebar of the VI. And this seems really to be the end going from bottom to top. When you have the reference of the library you will never get the project, neither with the property parent nor project.
 Your solution has the following advantages, besides the one it is working:
- You get the correct project file path even when two projects are loaded using the same library  and VI.
- You do not need to loop through a nested level of libraries. It works also in the case of nested libraries without modification.
Waldemar
(3,865 Views)
Hi Waldemar,
glad to hear it and thanks for the Kudos.
Have fun with LabVIEW.
With best regards
Ralf N.
NI Germany
(3,829 Views)
