Error 1013 when calling tdms viewer in host vi
Is TDMS file viewer supported in cRIO host vi? I looked in some knowledgebase articles, it seems like the front panel issue in target vi.
Please have a look at attached code. Is it possible to see wonderful tdms viewer results in my application?
Best Regards
(3,025 Views)
TDMS File Viewer is not supported on RT now, you can transfer the TDMS files to Windows and then use TDMS File Viewer.
(3,007 Views)
Transfer TDMS files to windows??? I wrote the tdms file in harddrive on my computer by giving file path to tdms open function. Could you tell bit further on how to get results please?? I am not entirely with you
Ta
(2,998 Views)
OK, so you run the VI period host.vi on your host desktop VI, right? Then where the TDMS files are? On the target or on the host?
We also saw error 1013 before, it always happened when you run your VIs with TDMS File Viewer on target, it should be no problem run the VI on host machine.
(2,980 Views)
