Error 1043 - Stop.vi
I am trying to debug my RT application with Desktop Execution Trace Toolkit 2015 and I am having this error.
For a couple of months, I did this with no issues.
Looking for this VI, I have found out that it is a part of Actor Framework, but I can't see any structures like (Invoke Node) inside this VI.
Has anyone experienced something like this?
Felipe Pinheiro Silva
Follow my blog for LV content!
(5,042 Views)
Hi Felipe,
Which LabVIEW version are you using?
This issue also occurs if you try the DETT in another project? (Can be a simpler one).
Did you try out reseting/reformating/reinstalling software to the controller and deploying the application to target again?
Are you using shared variable in your application? The below KB reports this issue can happen if deploying shared variable from RT Target. Make sure you are not doing that and deploy all variables from Host.
Error 1043 when Programmatically Deploying a Shared Variable on a Real-Time Target
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7k7SAC&l=en-US
Any question let me know.
Regards
Lincoln
(5,003 Views)
Hi Lincoln,
I am using LV 2015 SP1.
Thank you for your feedback.
This morning I tried installing a new version of DETT 2018, in a way that is backward compatible with LV 2015. However, it did not work.
So, I tried to use another controller with a simple project and it did not work either (no shared variables).
All I can think of now that it must be a problem with my DETT or LV installation.
I'll keep trying.
Regards.
Edit: It does work with simple local LV VI
(4,997 Views)
After trying some different configurations I figured out that it only works with one of our controllers (cRIO 9035) with embedded UI activated.
Another controller that we have (cRIO 9074) does not have UI, so it is still having some communication problems.
(4,985 Views)
Hi Felipe,
DETT was design for using on Windows Target. If you want to benchmark codes for Real Time Targets, the right tool is (Real-Time Trace Utility (RTETT).
Lincoln
(4,981 Views)
Accepted by felipe.foz
That's a pity.
Unfortunately RTETT it is not as intuitive as DETT, and as listed in description has limited functionality in Linux Targets.
In the VxWorks targets, we do not have any other choice otherwise using RTEET.
Thanks for the help.
(4,976 Views)
