Error 1054 Open VI Object Reference
Hi Ppl,
I'm using LabVIEW 8.6 and I'm debugging a code that uses the  Open VI Object Reference node. The parent reference thats passed in is a refrence of a VI instance and the vi object class is the control type. Though the control is present in the VI, the node returns error 1054 and says object not found.
I'm wondering why this was. However when the parent is the VI reference itself instead of the instance VI this works. I'm not able to understand the problem.
Sathish
Message 1 of 1
(3,209 Views)
