TL EL355P - EL302P
Just starting with Labview and managed to get some leds running and get some output on my parallel port.
So I already used the VISA part.
Next step is to use the TTI EL355p / EL302P DC powersupply, connected with RS232.
But I am a bit confused what to send to the VISA input?
I already managed to send *RST and *IDN?, sometimes I get a response and it goes to the *RST mode or gives the output as described under *IDN?
I wired a string to the VISA input and then send for example *RST
The powersupply goes to remote mode every time, baud rate is on 9600
(2,639 Views)
You send the commands that are in the manual the same way you sent the reset and identify commands. I would recomend the Format Into String function to create the voltage and current setpoint commands with a numeric control on the front panel.
(2,628 Views)
