Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error 1057
Why does this:
give me this:
(2,370 Views)
Accepted by topic author paul_a_cardinale
There is a difference between a Flat Sequence Frame and a Flat Sequence Structure.  I'm guessing you want the reference type to be Generic->GObject->Flat Sequence->Flat Sequence.
(2,359 Views)
The incoming object is not a diagram or sub-diagram of a structure object?
Rolf Kalbermatter  My Blog
(2,358 Views)
Hi Paul,
The correct class is "FlatSequence" (Generic -> GObject -> FlatSequence).
The class "FlatSequenceFrame" is for the frames of the FlatSequence.
Raphaƫl.
(2,355 Views)
