ā01-12-2024 02:37 PM
Why does this:
give me this:
Solved! Go to Solution.
ā01-12-2024 03:01 PM
There is a difference between a Flat Sequence Frame and a Flat Sequence Structure. I'm guessing you want the reference type to be Generic->GObject->Flat Sequence->Flat Sequence.
ā01-12-2024 03:02 PM
The incoming object is not a diagram or sub-diagram of a structure object?
ā01-12-2024 03:03 PM
