Error 1073 occurred at Property Node (arg 1)
the error 1073 occurs at Property Nodes in a VI I'm using, that calls FPGA VIs. I moved the Project to a new Computer and on the old one it worked fine.
I tried to not write to Label.Text, but it doesn't help.
The error message and the part with the Property Nodes are attached.
(2,771 Views)
Accepted by GermanStudent14
Pretty sure it's this problem
Can you switch to captions and use those instead?  And not write to the "Indicator" at all?
(2,764 Views)
Did  you read the Help for the Indicator Property? It is not settable when the VI is running.
There are ways to make an indicator appear to act as a control. For instance, I have used a Mouse-Down Event on an indicator and set the new value inside the event structure.
(2,753 Views)
