Error -1073807202 connection USB to send a SCL (Serial Command Language)
Hi
I have some problems to send a signal via serial port. I have to send it in SCL format (serial command language) to a driver that controls a stepper motor. I have some files that do this task (please, take a look the attached file). The company provides it (but they do not give any support, the company is Applied Motion)
The connection has to be made with a USB cable. First, I do not know if LabView recognizes the port (it is the COM3, according to the Device Manager of Windows)
When I tray to run the VI, the Error -1073807202 appears, What is wrong with those files?
Thanks.
(3,284 Views)
Nothing is wrong with the files. As the error message says, you have a missing driver and the missing driver is NI-VISA.
(3,266 Views)
Thanks, I just noticed that you are right. The driver was missing.
(3,253 Views)
