How can I convert/read out from a string Hex (8-bit), the bit 0 length 1
How can I convert/read out from Hex (8-bit), the bit 0 length 1 (string subset!!??) and convert it to decimal.
With respect to one complement and two complement ?
(2,795 Views)
OK we are going to need more information to help without serious guessing here.
What Type is the data you want to parse?  (String, U8,?)
String to array of U8>> U8 to boolean array>> Index array to get the boolean value for any bit or cast to I8 or U8?  I just can't tell from your discription.
(2,788 Views)
Just like Jeff, purely guessing here.
It almost sounds like you just need to Read from Binary File?
AND the 8-bit number with 1?
Need more details.  What exactly do you have to start with?  What exactly are you trying to get out of it?  Examples help.
(2,778 Views)
