Error-1073807202
Hi, anyone with any idea how to solve this issue?
(1,791 Views)
Well, you need to simply install the drivers.
(We typically can provide much better help with a bit more information: LabVIEW version (looks like 64bit)? Installed drivers? Source of the program? Did it work before? etc. )
(1,713 Views)
No, it is just newly installed. Does you driver means driver for the USB-blaster or Ni-Visa as shown in here NI-VISA Download - NI
(1,696 Views)
Possibly both.  But if your system recognizes the USB-Blaster, you probably already have the driver installed.
(1,660 Views)
Yes, I installed the USB blaster using quartus. Guess I will install the Ni_Visa first to see what happen will update about it.
(1,627 Views)
