Phase difference between digital inputs
I read digital signals from a Keyence GT2-71D LVDT, how can I get the time difference between the rising of the second signal and the falling of the first signal?
I tried with the Waveform monitoring VIs in the signal processing functions but I cannot transform the type of the wire.
I attach the VI I am using in case it helps.
(1,629 Views)
Hi Wavicle,
unfortunately you are using LV22Q3, which is not used very often so far.
You would get much more help when you downconvert your VI to LV2021 or even older! (Edit->Save for previous)
It also helps to provide typical waveforms with your VI, maybe as default data in some controls/indicators…
(1,591 Views)
Hi
I attach again the VI in LV2019, the waveforms I am trying to measure are digital pulses and I don't know how to create them as default data
(1,529 Views)
