Error -1073807343 occurred at Visa open in Stanford Research 830
I am running Labview 8.6 and am having some difficulties. When I attempt to run my program, it asks me to Choose file to write. I have attached a screen shot. I tried to write to a csv file.
Then I get an error that says:
Error-1073807195 occured at VISA Open in Stanford Research 830.lvlib:Initialize.vi->log_all_LI.vi
Possible reason(s):
Visa: (Hex 0xBFFF00A5) The interface type is valid, but the specified interface number is not configured.
Help please!
(3,580 Views)
The error has nothing to do with the file.
Use highlight execution and debug your code to find where this error happen.
Benoit
(3,537 Views)
Great! Thank you for suggestion the highlight execution. I am still new at LabVIEW so hang in there with me. Years and years ago this code was written for a research project. It was recently given to me to get working. I was given just the file and nothing more. If the program worked years ago, I would think no adjustments would need to be made. I wonder if it is a driver that I am missing or need to update?
I took your advice and debugged. Here is what I found:
I am attaching a screen shot of the layout where the error occurs in the beginning of the program. VISA resource name 1 has an I/O and the name it gives is GPIBO::9::INSTR. As soon as the program runs through his first initialize for VISA 1, it produces an error. Any hints? I am so lost at this point. Please help me. Thank you!
(3,523 Views)
Sorry attached wrong image. Here you go!
(3,522 Views)
Accepted by nsmit106
I have found the solution. Simple mistake. My virtual box was not recognizing that the device was connected. Now that it does recognize it, the device works.
(3,502 Views)
