Error -1074126846
Sorry for the confusion. I was referering to using the property node plus the add waveform processing VI (like the example) versus using a stand alone VI such as the ones found under Signal Processing/Filters.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
Message 11 of 12
(866 Views)
Paul,
When you use the property node and add waveform processing VI (like in the example), you are making calls into the Scope driver.  This means there is code in the driver to filter your signal.  When you use the other stand alone filtering VIs in LabVIEW such as the Bessel, Equi-Ripple, Buttworth etc you are using LabVIEW functions and you make calls into the LabVIEW.
Both the scope filters and LabVIEW filters are digital/software filters.  There is not much of a difference between using either one.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
Message 12 of 12
(849 Views)
